Supercharged 408 Build Up
Old Mar 19, 2009 | 03:27 PM
hydrashocker's Avatar
hydrashocker
Get flat top pistons for it!!!!!!!!!!!!!!!!!!!!!!
Old Mar 19, 2009 | 03:55 PM
Duranged408's Avatar
Duranged408
He's going to run SRP, guess he already has them. Just wondering what he plans on running compression wise with the supercharger.
Old Mar 20, 2009 | 10:10 PM
hydrashocker
365 Cubic Inch for .030 bore over? Part #142069
So what rings are you going with? The Premium part# J100F8-4030-5 or Sportsman part# S100S8-4030-5? Or something different?
Heads Gaskets I would intall FEL-PRO Severe Duty Part # 519SD
Also roller the whole thing!
Old Mar 23, 2009 | 03:24 PM
Durango911's Avatar
Durango911
Engines done and installed. I went with cometic head gaskets. It ran for about 10 miles, parked it, went to do a fuel sync on it and now it won't start. It's getting fuel and spark. I just replaced the crank positioning sensor and tried another 2 bar map sensor. I'm running out of ideas to try. I don't understand how it went from running to nothing at all. I'm waiting for my buddy to bring a compression tester over. This thing is driving me crazy.
Old Mar 23, 2009 | 05:51 PM
hydrashocker
Camshaft sensor.
Make sure that your TDC on #1 is sparking to ensure crank timing to the distributor.
Old Mar 23, 2009 | 08:17 PM
Durango911's Avatar
Durango911
I already replaced the crankshaft positioning sensor, no start. I changed the 2 bar map, fired up ran like crap. I changed plugs, fired up, runs really rich, map voltage is FUBAR'D. I'm on my way to go get another msd 2 bar map. Hopefully this works. If not, I'm going to stock injectors,map sensor and my B&G computer till I can get a good working map sensor! This is retarded. It's running so rich it won't idle and it fouls out plugs. I requested a leaner tune form my sct tuner, maybe that will help.
Old Mar 23, 2009 | 08:19 PM
Durango911's Avatar
Durango911
I have a spare camshaft sensor.(the one that goes in the distributor!) How do I know if thats bad?!
Old Mar 23, 2009 | 08:33 PM
DRO318's Avatar
DRO318
Hey what kinda coil you runnin???
Old Mar 23, 2009 | 10:03 PM
Durango911's Avatar
Durango911
stock,tried 2 other stock ones from my dakotas...no change
Old Mar 23, 2009 | 10:07 PM
DRO318's Avatar
DRO318
It's just me but I don't think the stock coil can handle the MSD ignition setup
For instance I have a friend with a "D" that tried using a stock coil and it failed after five days. Maybe it's the multiple spark thing
