Supercharged 408 Build Up
Old Mar 17, 2009 | 08:18 PM
Durango911's Avatar
Durango911
Lightbulb Supercharged 408 Build Up
I was wondering if anyone knew of a way to fit the turbonetics airhat on the holley throttle body without drilling a new hole? The holley TB is offset (same as a stock durango) and the turbonetics tube is dead center, made for a 4 barrel carb.
1999 Dodge Durango Project
Forged 408 built for boost (not assembled!) (Eagle Crank/Rods,SRP Pistons)
.555/.560 Duration 236/242 Camshaft (114)
Ported Edelbrock FI Airgap Intake
Ported Hughes Iron Ram Heads 2.02/1.620 Valves
Holley 52mm Throttle Body
Hughes Main Stud Girdle Kit
Crane 1.6 Roller Rockers
Powerdyne Supercharger with 6lb Pulley
Turbonetics Air Hat
Vortech Discharge Tube
Powerdyne In-line Fuel Pump
Ford Racing 42lb Injectors
2 Bar Map Sensor
SCT Tuned
Viper 2800 Stall Converter
Stock 3.55 Gears/Drivetrain
Old Mar 17, 2009 | 11:10 PM
hydrashocker's Avatar
hydrashocker
What about the flange turbonetics Part Number 21476 ?
Old Mar 17, 2009 | 11:34 PM
Durango911's Avatar
Durango911
I don't think that'll work. I copied the setup at http://www.rtmods.com/vortech_kits.htm It's supposed to work on stock dakota/durango. I'll ask them and see what they say. I guess I could just drill a new hole and tack the other one shut if I had to...
Old Mar 18, 2009 | 01:27 AM
Jasperstang308's Avatar
Jasperstang308
i hope the powerdyne supercharger for a durango is better then what they are for a mustang. they're known for grenading
Old Mar 18, 2009 | 07:37 AM
Duranged408's Avatar
Duranged408
http://www.bionicdodge.com/Download/...d%20Tricks.pdf
go down to "What is a S bolt and how do i make one"
Old Mar 18, 2009 | 02:55 PM
Durango911's Avatar
Durango911
The powerdyne's can safely run @ 6 PSI. They only grenade at higher boost because they weren't designed for it. You can get ceramic bearings,gates belt, and a performance impeller to hit 12+ PSI safely. Does anyone have the PDF file/instructions to use the factory belt tensioner on the powerdyne? I was told @ bionic dodge to also make an S bolt. I'm starting to build the shortblock tonight. I have the pistons/rods/rings together, and the main caps machined for the stud girdle kit.
Old Mar 18, 2009 | 03:40 PM
hydrashocker
Thanks.
Old Mar 18, 2009 | 03:52 PM
hydrashocker
That air hat should bolt up.
Other than that I'd just drill it and install a manual dial for pressure. (just an idea)
Old Mar 18, 2009 | 05:07 PM
Durango911's Avatar
Durango911
I'm not worried about it yet. Were about to start notching the block for the crankshaft and then assemble it. Hopefully I'll have it running this weekend.
Old Mar 19, 2009 | 07:09 AM
Duranged408
What ya plan on running for compression?
