hard shifting with engine oil change
Old Mar 23, 2009 | 05:25 PM
Durango03's Avatar
Durango03
Are you using 5w-30 or synthetic?
Old Mar 23, 2009 | 06:54 PM
hydrashocker's Avatar
hydrashocker
When is the last time you changed out the PVC valve?
Also, pul the Throttle Body off and clean that thing including all sensors. While you have it off take your flash light and look down the intake manifold. A little blow by oil accumulation is ok but if there is a lot the it could be a plenum gasket. The olny thing is you didn't say if you use a lot of oil which again would point back to the gasket.
Here is a DIY on it.
https://dodgeforum.com/forum/diy-do-...e00ram360.html
Old Mar 24, 2009 | 08:35 AM
stanger45's Avatar
stanger45
but why would changing the engine oil have anything to do with the shifting???
Old Mar 24, 2009 | 08:36 AM
stanger45's Avatar
stanger45
engine oil is 10w30 conventional
Old Mar 24, 2009 | 08:43 AM
DRO318's Avatar
DRO318
This isn't related to the trans but
I switched to full synthetic and it drives a lot smoother
Keep in mind "D"s tend to shift firm
Old Mar 24, 2009 | 08:45 AM
DRO318's Avatar
DRO318
Question when it shifts is it a clunk or just a firm lock shift???
Old Mar 24, 2009 | 09:13 AM
stanger45's Avatar
stanger45
when it finally shifts it's firm but like i said it takes about 1000mi on the ENGINE oil change before it makes it's shifts like normal, at first it streaches out the last shift forever!!!! normaly it would shift 1.2.3.4, after the oil change it shifts 1.2..3...........4
hope that makes sense.
Old Mar 24, 2009 | 09:21 AM
DRO318's Avatar
DRO318
Yeah it may just be the trans. If you never had the bands adjusted, or any other detailed service done to the trans I'd say take it easy on it till you have money saved up for a rebuild
Old Mar 24, 2009 | 09:22 AM
DRO318's Avatar
DRO318
It may also be the torque converter
When was the last time you had the fluid changed
Old Mar 24, 2009 | 09:29 AM
stanger45's Avatar
stanger45
ok, but why would it only happen after the engine oil change after the engine oil has 1000mi on it then it shifts normal until the next oil change
