Will not start
Old Mar 30, 2009 | 11:13 AM
teck78's Avatar
teck78
Unhappy Will not start
It was a nice day yesterday so i washed my durango 99 slt 5.9. i sprayed off the motor also. now it will not start all i get i a quick click click click. i know i got something wet but...what? Looking at getting the sensors for the ABS light to see if that fixes my ABS/brake light. My speedo works but, my abs pump never stops. i had to remove the relay for it.
Help....damn crazy dodge gremlins
T
Old Mar 30, 2009 | 11:39 AM
schusterjo's Avatar
schusterjo
Start with cleaning off you batter terminals real good, try jumping it and see if that would help, if so then you know its the battery area.
Old Mar 30, 2009 | 03:07 PM
hydrashocker's Avatar
hydrashocker
Yup!
The connections are the first place.
Old Mar 30, 2009 | 11:06 PM
DragonOfMadness's Avatar
DragonOfMadness
Sounds like your goina need to blow out the relay box and vicinty with air too=I wouldn't use any more then 40psi though...don't use a pressure washer on the engine nextime=you'll wash all that wholesome dodge goodness off=lol
Yeah, and those were Amc Gremlins....
Old Mar 31, 2009 | 12:10 AM
teck78's Avatar
teck78
Thumbs up Thanks
Well i did all the following and it started like a champ. hell my voltage even went up a bit. Thank you all very much. Oh yeah i got the rear abs sensor as well. hope to change it out tomorrow if i get the time. Thanks once again
T
Old Mar 31, 2009 | 12:57 AM
DurangoILNG23's Avatar
DurangoILNG23
Funny you mentioned washing the engine. I did mine also which may have led to the CAB module problem I had. First thing a friend advised I make sure all the ABS connections were thouroughly dry. Wasn't it.. BTW, I responded to your other thread if you are still having trouble with your ABS.
Old Mar 31, 2009 | 07:54 PM
hydrashocker
Nice to see you got-r-done!
Next time don't use a pressure washer......
Old Apr 1, 2009 | 12:17 AM
DragonOfMadness
If your gonna use a pressure washer don't wash the relay box or comps etc...And if your feelin froggy buy a tube of dielectric grease and disconnect ur negative terminal and put dielectric grease in every fricken electriclal terminal,relay,and wire connector, before you pressure wash ya rig's motor and don't forget a plastic bag over the dizzy{distributor}...
Old Apr 1, 2009 | 06:19 PM
hydrashocker
Or better yet....... Don't use one!
Old Apr 1, 2009 | 11:42 PM
DragonOfMadness
Pressure washer Rock out in hose fights with neighbors who have smoky bbq's,dogs that bark too f--kin much and noisy **** kid yellin during a backyard b-ball game...just use alil restraint on ya motor and let the aggression out on the rest of the populace=my comments are irreverent and should not be taken as the overall opinion of the DodgeForum.......lol
