Electrical Problems - HELP
Old Apr 3, 2009 | 09:38 AM
supermom1970's Avatar
supermom1970
Default Electrical Problems - HELP
I have had problems with electrical for over a year had it at a shop for 5 hours last year and found nothing when it rains out everything goes nuts in it wipers lights inside lights headlamps one stays on one goes off I take off the battery cable and leave it for a few min and its back to normal for a while what is going on with this I am so sick of this crap what did dodge do when they built this one.
Its a nice size vehicle love it but frankly Dodge is Bankrupt for good reasons I have been hearing more and more stories of the same thing going on does anyone have a real answer for me.
please help.
Old Apr 3, 2009 | 10:20 AM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
please help.
Welcome to DF supermom! Ill move this post over to its own thread in the 1st Gen Durango Section. Theres a bunch of good people there that should be able to help ya! Good luck and hope things work out for ya!
Old Apr 3, 2009 | 01:14 PM
schusterjo's Avatar
schusterjo
Sounds like you have a leak in your windshield somewhere allowing it to drip water over the fuse box. I drove a Semi that did this and man it was annoying. took me awile to figure it out but that is what the problem ended up being.
Other possibilities are water getting into the breaker box under the hood..
I should note that it is possible that u have a leak in ur windshield and your floor ext.. not get wet. This is what took me so long to find the problem with the truck I had. I did not find it till I started pulling things apart . I knew it had to be water related just had to find out where the leak was
Old Apr 3, 2009 | 05:25 PM
hydrashocker's Avatar
hydrashocker
I see you input info here.
Durango Electrical Problems? ( 1 2)
Old Apr 3, 2009 | 11:47 PM
DragonOfMadness's Avatar
DragonOfMadness
A cheap fix=buy a car cover....... Not so simple fix check the grounds to chassis and get a big tube of dielectric grease and smear all connections and grounds-Its messy but if you live in the rustbelt or northeast it's a must..and please disconnect the negative battery terminal when you do this=it will reset the comp after about 8hrs and the radio stations but it will help you in the end=to find windshield leaks hose the vehicle down for 10 mins then examine the underside dash area..stick with your d-rang=they are the best older suv's out there and the safest
Old Apr 4, 2009 | 11:58 AM
supermom1970
Smile Thank You very Much
I did have a new windsheild put in a few years ago and never even crossed my mind the windsheild.
Thank You so much for the info its been very frusterating now its time to go back to the windsheild guys and make them fix the problem.
thanks again
Tracy
Old Apr 4, 2009 | 05:22 PM
hydrashocker
Nice one schusterjo!
Now if she'll come back and give us some female members over here.
Old Apr 4, 2009 | 06:07 PM
schusterjo's Avatar
schusterjo
Ya no kidding...
Old Apr 4, 2009 | 06:38 PM
Duranged408's Avatar
Duranged408
last time i hike up my skirt for you...
Old Apr 4, 2009 | 11:41 PM
hydrashocker
You bastered!........
Well next time leave some sugar baby and I'll keep ya!
