transmission/engine leak
Old Mar 6, 2005 | 11:27 PM
hchorney's Avatar
hchorney
Default transmission/engine leak
I recently took my 99 Durango 4x4 5.2 in for an oil change (66,000 miles). My car was perfect before, but now seems to be seeping oil from where the engine connects to the transmission.
Is this a common problem and what can I do?
Old Mar 8, 2005 | 12:14 AM
lamrouex2004's Avatar
lamrouex2004
Default RE: transmission/engine leak
I have the same problem, but its my transmission that is leaking...mine isnt major but I noticed it when it was on the lift. (front main seal) It's a common problem with these durango's...if your lucky, the dealership might help you out because this is a known problem and is listed under their TSB's. I'm hoping they will recall it but I doubt it.
