I put a FASTMAN SIMM on my 99, is it alright
Old Apr 12, 2009 | 05:01 PM
dscdad77's Avatar
dscdad77
Default I put a FASTMAN SIMM on my 99, is it alright
I cut out the cat on my 99 durango, welded in a straight pipe and added a fastman simm for the post o2. I keep throwing a p1495 leak detection pump code. I can't find a leak in the evaporative system but I am not sure if I am checking the whole system. Could this leak be in the exhaust? Maybe at the crankcase filter? If it still throws the code should I go ahead and change the plugs and wires or will they get ruined from the truck running in safe mode? Should I just replace the ldp? This seems to be turning into a nightmare.. Any suggestions would be greatly appreciated..
Old Apr 12, 2009 | 07:21 PM
schusterjo's Avatar
schusterjo
when installing the SIMM did you take the negative battery terminal off?
Old Apr 12, 2009 | 09:15 PM
dscdad77's Avatar
dscdad77
Default fastman simm
should have I taken the neg terminal off?
Old Apr 12, 2009 | 10:06 PM
schusterjo's Avatar
schusterjo
I just replied to ur PM...
