no bus on odometer and stalling
Old Mar 8, 2005 | 03:28 AM
bugin's Avatar
bugin
Default no bus on odometer and stalling
no bus on odometer, stalling.Replaced the crank sensor and fuel pump. Still have the same problem. PLEASE HELP
Old Mar 8, 2005 | 02:01 PM
ricocivi's Avatar
ricocivi
Default RE: no bus on odometer and stalling
Had the same problem with my '99 Durango (no bus on odometer & stalling). I also changed the crankshaft sensor. The problem is definitely the PCM (Powertrain Control Module). It costs about $500, and is only a few screws to change, but I had to have the dealer install it because it has to be reprogrammed for the keyless entry & alarm to work correctly (final cost $800). I spent months trying to figure this out and more than 100 hours on message boards, emailing, etc. Once the PCM was replaced, the problem was solved. Good luck!
Old Mar 23, 2005 | 06:58 PM
kay1330's Avatar
kay1330
I too had this problem, took it the dealer and they replaced the ctm, did not fix problem and was not under warranty($325). I forced them to replace the pcm and it fixed the problem and was covered under emmissions warranty up to 80,000 miles I think. Good luck.
