BILSTEIN or MONROE??
Old 04-24-2009, 03:56 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Good deal!
They won't ship after morning........ Next day for sure!
  #22
Old 04-25-2009, 01:04 AM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
That's a great price!
IndyD
  #23
Old 05-02-2009, 07:03 PM
MAGIC84's Avatar
MAGIC84
MAGIC84 is offline
Bilsteins, installed all 4 corners. Took about 2 hours for back and 1 hour for fronts. Only major issue was trying to get a bite of the shock piston rod to loosen the upper nut. I was trying to get a good bite to hold, but not gauge the metal. I had to slide the dustboot down to grab the rod but I got it. Penetrating blast for 24 hours prior to removal helped out. Bilsteins did not come with new bolts, so dont plan on that incase you are a head stripper or thread gouger....LOL!! It did have new nuts for the upper but thats about the only new hardware. FYI Rear tires were able to be left in place, fronts did have to be removed.
On a Sidebar, the CV axle I had replaced last July is already cut on the outer dust boot.
Based on the observations of the removal of the old shocks, I thinkg I have a theory of how the new one got cut. Hear me out and see if it seems plausible or is it Myth "BUSTED" The OEM shocks have a outer cylinder with potentially sharp edges from top-bottom and with wear , the shock was riding down on the boot, and cutting it. I think the New Bilsteins with the dustboots, might have cured it. I will talk to Advance and see about a warranty replacement but if not then I might have to get a new one.. Only seems to happen on the RH side though. Any thoughts? Oh well, shocks in, good fit and much better ride. Install mileage approx 102.7K Thanks for all the help.
Steve
  #24
Old 05-02-2009, 07:22 PM
IndyDurango
Let us know if under acceleration on a real bumpy road you find the rear end hop/sway to be greatly eliminated with your Bils. They was the only thing I could find to cure my same situation.
Good luck on the boot issue. Anything is possible, If it was even slightly touching and turning, the boot could had a lathe-like action and been cut.
IndyD
  #25
Old 05-02-2009, 11:36 PM
hydrashocker
Pictures please!
  #26
Old 05-03-2009, 01:05 AM
IndyDurango
Originally Posted by hydrashocker
Pictures please!
  #27
Old 05-03-2009, 05:03 AM
MAGIC84's Avatar
MAGIC84
MAGIC84 is offline
I wish you had asked for photos earlier! Do you need photos of the cut on the boot or the old shock? Old shocks already thrown out. Fyi They were OEM shocks, even had a JUL 03 build date stamp. I Can get photos of the boot tear hopefully before it gets much worse.
  #28
Old 05-03-2009, 02:20 PM
hydrashocker
Ya, take a pic of the problems areas your talking about.....
Indy<------------ Thats making my *** jones for a lil campin & fishin!
  #29
Old 05-03-2009, 02:34 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
Good move, I'm a real fan of Bilstein shocks, I haven't bought anything other than that or Rancho's for any of my trucks or suv's in over 16 years...
  #30
Old 05-04-2009, 02:01 AM
M Shark's Avatar
M Shark
M Shark is offline
I've used billsteins for years when I was still tracking my M3. So I've put them on as replacements to the stock shocks and I can really notice a difference on hard cornering. More stability, more predictable turn in, and only a little "oh $hit" factor noticed.
Quick Reply: BILSTEIN or MONROE??
