Poor fuel mileage
Old May 12, 2009 | 08:44 PM
  #51
IndyDurango's Avatar
IndyDurango
[HYDRA If I order plugs then I order 9 plugs because I could break one."/]
needs to be changed to the following: Your missing info is in BOLD
{quote=Hydra} If I order plugs then I order 9 plugs because I could break one."{/quote]
change the "{' to "[" to get everything to work correctly (and "}" to "]" to the other side too)
Old May 12, 2009 | 08:47 PM
  #52
IndyDurango
Originally Posted by hydrashocker
Ya,
Ordering always sucks but thats when you get a couple of other things you've been needing while your there. Then again It takes a coulpe of days but in the end you get what you want. If I order plugs then I order 9 plugs because I could break one. Then I just keep the extra on hand from there on. I looked on www.summitracing.com and theres were more money.
CPN-4318 Champion Truck Plug Spark Plugs
Spark Plug, Truck, Flat Seat, 14mm Thread, .750 in. Reach, Resistor, Each
Today$2.95
Stock temp or one range cooler on that number provided?
IndyD
Old May 12, 2009 | 09:26 PM
  #53
MAGIC84's Avatar
MAGIC84
By the time I figure out the quotes it will be time to change the plugs again...LOL!!!
We should have a separate thread for learing how to enter quotes.
Old May 12, 2009 | 09:40 PM
  #54
MAGIC84's Avatar
MAGIC84
[= quote Indy D Stock temp or one range cooler on that number provided/quote]
Specs directly from Champion website 4318 TRUCK PLUG
Truck Plug, 14mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size,
Gasket Seat, Resistor','2','1')">Resistor, Projected Core Nose, Heat Range 12
OEM COPPER
Gasket Seat, Resistor','2','1')">Resistor, Copper Core, Projected Core Nose,
Heat Range 12
Sounds like Heat range is same for both of them.
Old May 12, 2009 | 11:53 PM
  #55
IndyDurango
{quote=Indy} D Stock temp or one range cooler on that number provided{/quote]
LOL ROTFLMAO
Correction entered below your attempt.
Using the CORRECT bracket style, you get this:
It's "quote=name" and all commands START and END with brackets [ & ]
Your = is in the wrong place, missing the opening bracket and missing the ending bracket. No spaces within the quote either.
funnier thing is simply clicking on the link to quote and computer does it for you.
Old May 13, 2009 | 07:38 AM
  #56
Duranged408's Avatar
Duranged408
Originally Posted by IndyDurango
Yeah and its fun changing the text in a quote , but this time i'll be nice.
Old May 13, 2009 | 03:38 PM
  #57
MAGIC84's Avatar
MAGIC84
Duranged, Stop with the madness, remember what happened last thread when you started posting these photos. You are o.k but Hydra and Indy get out of hand. LOL!!!
Old May 13, 2009 | 04:01 PM
  #58
MAGIC84's Avatar
MAGIC84
OEM COPPER
Heat Range 12
Old May 13, 2009 | 04:03 PM
  #59
MAGIC84's Avatar
MAGIC84
I did it, read last post, next step is to quote other members. Indy, do I get a cookie?
Old May 13, 2009 | 04:56 PM
  #60
hydrashocker's Avatar
hydrashocker
Just go to the post you want to quote and on the post you will see on the bottom-right side the botton.
After it loads the post will be there in the right format. You simply erase the parts you don't want and under the final "[/quote]" line type your statement.
This will post your quote overhead and under it will be you statement.
