Dimensions of OEM Infinity amplifier.
Old Feb 27, 2010 | 11:31 AM
Kensai's Avatar
Kensai
Here is the product summary for the Blaupunkt THA 475 PnP 4-Channel Class-D Car Amplifier:
"Finally, the perfect solution for improving the sound on stock car audio systems simply, quickly, and without violating your lease agreement. Blaupunkt’s THA plug and play amplifiers install in over 2000 car models in under fifteen minutes with absolutely no crimping, splicing, soldering, or hassle of any kind. Plus, they come out as easily as they go in – making it simple to return your car to stock form at the end of a lease. Blaupunkt’s complete range of over 40 vehicle-specific wiring harness adapters supply every connection necessary, including power*, with a simple plug – and they work with nearly any car, including those with complicated bus systems that eliminate the possibility of installing conventional amplifiers. The THA amplifiers are cool-running class D designs that are 65 % smaller than the competition, and install almost anywhere – including tight spaces behind the dash or under the front seats. These amplifiers are simply the only solution for improving stock systems in today’s world of complicated car electronics and leased vehicles."
Technical specifications:
4-channel car amplifier
RMS power (4 ohms): 4 x 75 W / 2 x 180 W
RMS power (2 ohms): 4 x 85 W
Max. power (4 ohms): 4 x 150 W / 2 x 360 W
Variable low-pass filter (50-250 Hz)
High-pass/subsonic filter (10-250 Hz)
Full-range Class-D amplifier design
Direct auxiliary input
Fuse rating: 30A x 1
11-1/4"W x 1-11/16"H x 7-1/4"D
Note the size of this amp. It closely matches the dimensions of the OEM amp with the brackets. Users also posted reviews that this amp runs pretty cool under load so you won't have to worry about excess heat build up behind the kick panel. I also like the idea that this amp can easily integrate with OEM equipment without all the retrofitting! I hope they have one for Dodge audio systems.
Old Jul 7, 2010 | 08:53 AM
Glennh61's Avatar
Glennh61
Default Durango amp
So have you tried this amp yet? I installed the infinity 6012 speakers and I can barely hear the rears.
Old Jul 8, 2010 | 12:59 AM
Kensai's Avatar
Kensai
This is my problem also. The rears are weak compared to the fronts. Not sure if it is the amp. I already got this amp in mind and will have it budgeted for next month to get it installed!
From amazon.com, some good reviews. Especially some owners that actually installed it in their 1st gen Dakotas which should match the Durangos at the passenger side kick panel. Owners said it was an easy straight forward replacements without having to drill new mounting holes. No wires to splice. Direct plug and play.
Old Jul 8, 2010 | 06:56 AM
Glennh61's Avatar
Glennh61
Don't wait too long, almost clicked on "buy now" but couldn't find how to order the right cables. Amazon only had 4 left. Discontinued on crutchfield.
Old Jul 8, 2010 | 09:28 AM
Kensai's Avatar
Kensai
damn, oh well, if they're gone, they're gone then. This amp is on the lower end of my project wants. My primary upgrade will be the airgap intake manifold upgrade! I am sure these units may turn up on ebay or somewhere.
Old Jul 8, 2010 | 09:51 AM
Kensai's Avatar
Kensai
Glen,
Here you go, the pnp adapter for the amp for our durangos. $9.99 from sonicelectronix.com.
http://www.sonicelectronix.com/searc...&action=search
Part # 7 607 622 027 001
PDF for adapter part numbers for almost all vehicles for the blaupunkt.
http://www.sonicelectronix.com/manua...ste_250407.pdf
Lowest price for the Blaupunkt amp found on internet as of 07/08/2010: $254 from pricegrabber
http://www.pricegrabber.com/user_sal...lot_id=8975527
Old Jul 9, 2010 | 10:10 AM
Glennh61's Avatar
Glennh61
Thanks for the info. Checked out pricegrabber, it links to discount jungle, couldn't find a place to click buy. Tried to go to website, didn't work. Googled them, found some BAD reviews. eBay has 1 seller for 320+20+cables. Maybe I'll just put the money in my gastank lol
Old Dec 31, 2010 | 11:54 AM
Kensai's Avatar
Kensai
Default Ebay has 8 of these left for $97 with s/h
I just bought this blaupunkt today from ebay. Brand new unopen box. They have 8 left after I bought mine! Better get yours before it's all sold out.
This amp usually goes for $250-300 bucks!!!
This is the only aftermarket 4 channel amp that will perfect replace the oem amp at its original location at the passenger side kick panel with little or no modifications.
EBAY LINK:
http://cgi.ebay.com/BLAUPUNKT-THA475...item35add86ac6
Old Jan 3, 2011 | 10:04 AM
Glennh61's Avatar
Glennh61
Thanks Kensai, I just ordered one also, with cables from sonic. Glad I waited!!
Old Jan 3, 2011 | 12:07 PM
Kensai's Avatar
Kensai
Oh crap, I completely forgot about the adaptor cables! Thanks, going to get them from Sonic as well.
Do you have the link to it by chance?
ooops, nevermind, I had the link already on my previous post!
