Dimensions of OEM Infinity amplifier.
Old Jan 15, 2011 | 06:25 PM
  #21
Kensai's Avatar
Kensai
I got my amp in. Did some more googling on the net and came to find out, this amp is will not be exactly plug and play for systems that uses a OEM amp. The plug and play harnesses were made for oem systems without an OEM amp.
Now I will have to find a wiring schematic at the OEM infinity amp location to know what all the wires are and then manually connect them to the Blaupunkt. Does anyone have a schematic of the plugs at the OEM amp location???
Old Jan 16, 2011 | 06:20 PM
  #22
Glennh61's Avatar
Glennh61
u are correct. the new amp only works if you leave the factory amp plugged in. i de-soldered the plug from the stock amp and plan to use it as part of a new harness. i asked my son to use alldata at his school to see if he can get the schematic
Old Mar 17, 2012 | 03:09 PM
  #23
dompie99's Avatar
dompie99
DAMNNNNnnnnnn
I've been looking for the specs of Infinity OEM amps all over the web without any luck. The one i found was this PN: P04671236
is there a site that hass ALL the ratings of these Originas amps from Chrysler corp ??
