Well this just isn't good. Not even a little bit.
Old May 9, 2009 | 02:04 PM
THEBIGSITT's Avatar
THEBIGSITT
Unhappy Well this just isn't good. Not even a little bit.
So my brakes have been squeaking, and I didn't feel like looking at them myself, so i took them to Midas to have them look at them and then I would fix it myself. After receiving their $800 estimate, i said no thanks and I would like to go home. They put her back together and sent me on my way. I went home and got ready to leave for work. Well when I get in the Dango and start her up, she won't fire. The engine is turning and everything, but it won't turn over. It is almost as if I am out of gas, but I know that I am not. I even put some gas in to make sure. When I tried again after work, it still wasn't working. Does any one have any idea what is going on???????
Old May 9, 2009 | 03:26 PM
hydrashocker's Avatar
hydrashocker
Fuel pump, or spark!
Old May 10, 2009 | 09:32 AM
schusterjo's Avatar
schusterjo
Ya man there is a list of diag you need to do before we could really help you.
1. is it getting spark?
2. is it getting fuel?
fuel pressure?
3. getting any codes?
Old May 22, 2009 | 10:30 PM
THEBIGSITT's Avatar
THEBIGSITT
I found out what is causing the problem. Sometimes when I take the parking break off, the engine relays fuse blows. It happened to me today and I replaced the fuse, and restarted the truck, took the parking break off, and it blew again. Does anybody know what may cause something like this to happen? I had it fixed about two weeks ago and it ran fine until today.
Old May 23, 2009 | 11:25 AM
Neo1130's Avatar
Neo1130
Are you the one with the remote start? My books are packed right now or I would look it up for you... But I would get under there and see if there is anything chafing against the brake lever and it components.... There are a few wires that run near it...
