abs help
abs and brake light on intermittenly. I replaced rear sensor, worked for a while then came on ,my speedometer works fine.
off when i start out but almost always turns on sooner or later. ran ohm test on fronts, looked good. Has anybody else had this problem? I see alot with speedometer problems at the same time and the rear was the problem. My pump works good so the controller is okay but will be next to change out,
then bearinga and sensors. Trans out put sensor i dont thnk would do that but i dont know for sure.
