help hard starts
Old May 17, 2009 | 07:59 AM
wuwu791's Avatar
wuwu791
Default help hard starts
i have a 2003 dodge durango sxt 4x4 with the 5.9 liter engine.when it rains or there is moisture in the air the truck has hard starts.i have to hold the gas pedal down for a few minutes,till the engine gets up to temp.then the idle will hold and i can drive away.other wise it just shuts off.what can this be?
Old May 17, 2009 | 12:55 PM
hydrashocker's Avatar
hydrashocker
Most likely a battery connection or a crank shaft sensor on a 4.7L
Please advise us on the motor we are working on?
Old May 17, 2009 | 03:03 PM
wuwu791's Avatar
wuwu791
sorry about that.it's the 5.9 liter engine
Old May 17, 2009 | 03:04 PM
IndyDurango's Avatar
IndyDurango
How old is the cap, rotor, plugs and wires?
IndyD
Old May 17, 2009 | 03:11 PM
wuwu791's Avatar
wuwu791
i bought the truck about 2-3 yrs ago.and it was doing the same only not as bad.i personally have not replaced any of those items.
Old May 17, 2009 | 03:43 PM
IndyDurango
No ignition = no power.
My suggestion is to get a new BRASS cap and rotor from NAPA. Ask for Echlin. Get new plug wires (8MM in size at least) of any brand you like. Get new plugs and a new coil. It will set you back $200 if you do it yourself (fairly easy) and takes about an hour.
http://www.napaonline.com/masterpage...istributor+Cap
http://www.napaonline.com/masterpage...tributor+Rotor
http://www.napaonline.com/masterpage...=Ignition+Coil
IndyD
Old May 17, 2009 | 05:50 PM
wuwu791's Avatar
wuwu791
it cranks up fine. but won't stay on for some reason
Old May 18, 2009 | 12:04 AM
IndyDurango
Low idle stumble at start up is nearly always a bad battery... believe it or not.
IndyD
Old May 19, 2009 | 06:07 PM
hydrashocker
Still could be the tune up issue like Indy is saying. Tune that thing up and route the wires so they are off the motor and eachother as much as possible. I would recommend OEM wires tho.
