2000 durango shaking
Old May 21, 2009 | 12:12 AM
grit44's Avatar
grit44
Default 2000 durango shaking
i have a 2000 durango and it shakes in the lower rpms and when idleing. it stops for a little bit then starts up again. i was told that the timing was off but im not sure if thats it
PLEASE HELP!
Old May 21, 2009 | 12:15 AM
dhvaughan's Avatar
dhvaughan
timing is controlled by the computer and not really adjustable. its probably skipping on a cylinder. check plugs, wires, rotor, cap.
Old May 21, 2009 | 12:19 AM
grit44's Avatar
grit44
if that was the case would it feel like it lost power because it still pulls like it did when it was running fine
Old May 21, 2009 | 05:57 PM
schusterjo's Avatar
schusterjo
Need to do a tuneup if you have not done so in a long time..
Champion plugs (just the cheap ones will work fine, stay away from platinum)
(if not a 4.7L, no plug wires)
8MM wires or 8.5MM
Cap/rotor with brass or copper contacts (Napa or leading brand, don't buy the cheapest)
Run a bottle of fuel injector cleaner thew it.
Clean out the throttle body..
Replace air filter..
Clean battery terminals real good (wire brush works great, just take the terminals all the way off and do a good job)
You do all that and you still have issues then we can be able to narrow it down more.
Old May 21, 2009 | 06:38 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
8MM wires or 8.5MM
excatly what i was going to say
and while im here we need some more info such as engine size, miles 4x4/4x2????? will give us a better idea of what we have to look at here, and what could possibly be going out at this point in your D's life
Old May 21, 2009 | 11:59 PM
grit44's Avatar
grit44
192000 miles not 4x4 and its got the 5.2 in it
i put new plugs in it the d cap was the next thing i was gonna do
thank you guys
Old May 22, 2009 | 08:39 AM
shrpshtr325
THE ULTI-MOD
any error codes (check engine light on???) try the keydance trick to pull any codes that might be there (even if the light is off it can still have codes sitting there) and let us know what they codes are if there are any
and my old truck had a misfire which made it shake like crazy (3.9L dak) and it did NOT feel like it had lost any power, the misfire was caused by bad plug wires (brand new) out of the box so if it showed up right after changing wires or doing something like that try UN-doing it temporarily to see if the problem goes away and if so take back the part you changed and get your money back
Old May 25, 2009 | 12:11 AM
hydrashocker's Avatar
hydrashocker
I've seen bad wires out of the box as well.
Old May 25, 2009 | 09:50 AM
schusterjo's Avatar
schusterjo
Got to love that quality control they have in foreign countries... getting just as bad here anymore though to tell you the truth.
