Idle Issues??? Help!!!
Old May 22, 2009 | 06:46 PM
Bonz's Avatar
Bonz
Default Idle Issues??? Help!!!
I have a 99 Durango Slt, 5.2L 4x4. I do not run it daily, it has 110,00 miles on it and recently I have had a problem with it not wanting to idle at all.
it runs like a champ as long as you have your foot on the gas ever so slightly. if you remove your foot it stalls? however it will fire right back up and run fine as long as its getting a little pedal?
Any Ideas before i start spending money blindly? it has newer plugs, wires, cap and rotor. is there an idle adjusment? maybe a computer issue?
any help is really appreciated !! Thanks!!
Old May 22, 2009 | 08:54 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
change out the IAC motor, its the little motor on the back of the throttle body, they stop functioning properly and the truck wont idle right of at all. They can SOMETIMES be cleaned but for the cost of them its better off to just replace it, that is the most likely candidate for a solution
Old May 23, 2009 | 10:59 PM
hydrashocker's Avatar
hydrashocker
Yup!
Clean the throttle body and IAC out with a brake cleaner or fuel injector/carb cleaner really good. If it persists then replace the IAC like Sharp says. Remember to reset the PCM.
Engine Code Index (Check Engine Light?)
Old May 24, 2009 | 02:02 AM
IndyDurango's Avatar
IndyDurango
Low idle stumble... ESPECIALLY at start up... is usually a bad battery. Believe it or not.
IndyDurango
Old May 24, 2009 | 09:47 AM
Bonz's Avatar
Bonz
cleaned the throttle body and IAC, worked like a charm!! Thanks fellas for the great answers. I will probably replace the IAC rather than worry about it in the fuure.
Old May 24, 2009 | 10:43 AM
MAGIC84's Avatar
MAGIC84
Another satisifed customer!!!!
Old May 24, 2009 | 11:58 PM
hydrashocker
Now if he comes back?
Old May 25, 2009 | 09:16 AM
shrpshtr325
THE ULTI-MOD
we can only hope he stays on with us
Old May 27, 2009 | 09:13 PM
Bonz's Avatar
Bonz
I'm defintely stayin around! I wish I'd have known about this site a little sooner, coulda saved some headaches and money!! As much as I love my Durango, she's been a pain in the rear lately, as most ladies can be!!
Old May 27, 2009 | 10:50 PM
Kensai's Avatar
Kensai
Better late than never. Be sure to read our DIY thread stickied at top of the durango 1st gen forum if you want to read more about common issues and fixes for your 1st gen durango.
