O2 Sensors
Old May 23, 2009 | 08:06 PM
BeachBoy's Avatar
BeachBoy
Default O2 Sensors
Hello. Brand new to the forum, as I just bought an '00 Durango 4.7. Engine codes are coming up 0132 and 0138. My question is: does this neccesarilly mean that both sensors need replacing, or is it likely an electrical problem if both sensor codes are popping up? Thanks
Old May 23, 2009 | 09:39 PM
Neo1130's Avatar
Neo1130
http://www.dodgedakotas.com/boards/v8/10954.html
Old May 24, 2009 | 07:44 AM
BeachBoy's Avatar
BeachBoy
Thanks. I'll take a good look at the wiring before dropping a couple hundred bucks.
Old May 25, 2009 | 12:09 AM
hydrashocker's Avatar
hydrashocker
There is most likely a wiring harness issue. Check all the plugs with it and use a multimeter.
Old May 31, 2009 | 07:54 PM
BeachBoy's Avatar
BeachBoy
Thanks guys. Looks like an attempt was made by the previous owner to fix the short by connecting the wires directly on the upstream sensor. That's right, no harness for some reason. On a semi-related note, the water coming from the A/C is dripping down directly on the muffler near the sensor. Common?
Old May 31, 2009 | 10:20 PM
hydrashocker
Sounds like a tube is missing or can be incorporated. Either that or move the muffler.
