ATF+3 Superseded
Old Jun 15, 2009 | 12:05 AM
hydrashocker's Avatar
hydrashocker
Default ATF+3 Superseded
Well when I was up at the Dealership and tried to get some more stock pile and they've run out.
So sounds like it's ATF+4 now. Thats ok because it's better anyway just thought I'd let everyone know it's gone.....
Old Jun 15, 2009 | 01:02 AM
IndyDurango's Avatar
IndyDurango
Still available aftermarket however right?
IndyD
Old Jun 15, 2009 | 09:37 AM
lv360ram's Avatar
lv360ram
I use Valvoline ATF+4
Old Jun 15, 2009 | 07:36 PM
hydrashocker
No,
Thinkin thats about it now. I haven't found it at any place?
Old Jun 16, 2009 | 10:49 AM
Kensai's Avatar
Kensai
+2. I recently did a tranny fluid change and just out of curiousity, was looking around for any ATF+3 and none exist. Only ATF+4 avail now. Seems that Valvoline is the only ATF4 fluid out there as aftermarket fluid. I was not able to find any alternate makers that makes ATF+4.
Damn, walmart charges $4.97 per quart of Valvoline ATF+4. Napa charged me $4.50 a quart.
Old Jun 16, 2009 | 07:06 PM
MetalDrgn's Avatar
MetalDrgn
http://dodgeram.info/tsb/2006/21-010-06.htm
check out the link^
...NOTE: ATF+4® is backward compatible with ATF+3 , ATF+2, and ATF+. Additionally,
ATF+4 can be used to top off vehicles that used ATF+3, ATF+2, or ATF+.
NOTE: If ATF+4® is used to service models originally filled with ATF+3 , ATF+2, and
ATF+ the fluid maintenance schedules listed for that model does not change.
The service interval currently in effect for a given model should continue to
be followed. Refer to the Service or Owners manual for maintenance
schedule directions.
In general terms, If ATF+, ATF+2 or ATF+3 was the recommended fluid, it is now
recommended to use ATF+4...
Old Jun 16, 2009 | 07:54 PM
Kensai's Avatar
Kensai
The rule of thumb is that you can always go wtih a higher grade fluid, but cannot get a lesser grade fluid below the required minimum.
An example would be a car requiring regular unlead can use premium unlead. But a car requiring premium unlead cannot use regular unlead.
Old Jun 16, 2009 | 11:24 PM
IndyDurango
http://www.centerforqa.com/home.html
Licensed ATF+4 Brand Names
Remember, for best performance and vehicle warranty compliance select only licensed ATF+4® for your Chrysler®, Jeep® or Dodge® vehicle. Use of non-licensed ATF brands may damage your vehicle or void your warranty. Please contact us to report unauthorized use of the ATF+4® trademark by non-licensed brands.
Advance Auto Parts ATF+4®
Carquest ATF+4®
Castrol ATF+4®
Chevron ATF+4®
Citgo Transgard ATF+4®
Coastal ATF+4®
Conklin ATF-Xtra Plus ATF+4®
Formula Shell ATF+4®
Great Wall ATF+4®
Havoline ATF+4®
MAG 1 ATF+4®
Mobil ATF+4®
Mobil Super ATF+4®
Mopar ATF+4®
MotoMaster ATF+4®
NAPA ATF+4®
Northland ATF+4®
O’Reilly ATF+4®
Parts Master ATF+4®
Parts Plus ATF+4®
Pennzoil ATF+4®
Petro-Canada ATF+4®
Quaker State ATF+4®
Ravenol ATF+4®
Sinopec ATF+4®
Super Tech ATF+4®
Texamatic DC ATF+4®
Ultramax ATF+4®
Valvoline ATF+4®
Plenty-O-Choices! Name:  beer.gif
IndyDurango
Old Jun 16, 2009 | 11:45 PM
Kensai's Avatar
Kensai
Wow, those are alot of choices. Too bad I never seen any of them in my area (Napa, autozone, walmart) except for Valvoline brand. Maybe it's this particular area of DFW that valvoline tranny ATF+4 reigns!
Old Jun 17, 2009 | 12:25 AM
IndyDurango
I bet there are not that many makers of ATF+4, it's just resold and rebranded by that many.
Rumor used to be that Valvoline was the OEM manufacturer for Mopar's ATF+4. Interestingly, the formulas between the Mopar version and the Valvoline concoctions are different.
IndyDurango
