After 7 years finally something happened!
Old Jun 21, 2009 | 09:35 PM
thepeshmode's Avatar
thepeshmode
Default After 7 years finally something happened!
Bought my Durango brand new and just today something finally happened.
On my way home on the freeway, I heard a couple of pops while on cruise control. Took it off and several more pops and then I started losing power, the RPM climb to 4.5K so I shift to neutral. Tried to shift back into drive but had no power train. I noticed before the oil guage showed no pressure and still had enough speed to make it into the right shoulder. Now when I try starting it, the engine just turns over. I know the starter is o.k. Couple of times I"ll hear the enging trying to catch. but will hear some "poofing" so I think the timing chain is o.k. Check guages light is off and engine light goes off when I start the D. Cables to the coil and distrubutor are still connected. Any ideas?
Old Jun 21, 2009 | 10:23 PM
hydrashocker's Avatar
hydrashocker
1. Check the spark.
2. Check the fuel pressure.
3. Check the compression.
If all good then I'd move to the TPS, Crank Sensors, or PCM.
Old Jun 21, 2009 | 11:47 PM
IndyDurango's Avatar
IndyDurango
No Check Engine Light codes?
If no codes... My money is on the coil failed ($50 fix and 10 minutes of work.)
IndyDurango
Old Jun 21, 2009 | 11:48 PM
thepeshmode
While waiting for tow truck I tried starting again 10 minutes later. The Durango start right up and ran for about 15 seconds. Normal start up, normal run. Oil pressure built up. All o.k. until I press the 'gas' pedal. Saw dried up antifreeze around the radiator cap. Took the cap off and started the D up again. Saw no antifreeze flow so now wondering if the radiator is empty and or water pump gave out. I just finished with a 150 mile trip back into Phoenix.
Old Jun 22, 2009 | 12:29 AM
IndyDurango
If it really overheats, the D will go into "Limp-Mode". Get some fluids in there and see.
Look straight down on the t-stat. If residue there from a fluid leak, replace the stat and gasket. That's a common point of failure.
If it is the low fluid/high heat condition... you should have seen it raise on the temp gauge. Here's hoping nothing went bad from there!
IndyDurango
Old Jun 22, 2009 | 10:57 PM
hydrashocker
Hmmmmm..... Could be the heat cutting it off.
