'00 Rear Pinion Seal Leakage
Old Jun 22, 2009 | 06:38 PM
datacop's Avatar
datacop
Question '00 Rear Pinion Seal Leakage
My rear pinion seal is leaking the diff's life blood onto my drive way.
There's not much I'm afraid to do on a vehicle (except for auto-trans.. that's black magic voodoo to me) so I want to fix the diff myself. I got a bearing and seal kit from Napa and referenced both my chilton and the 2000 D/C Service manual for the repair...
All in all, it doesn't look like it's a difficult job to do in and of itself, just time consuming and a pain in the rear to make sure everything is "right" when putting it back together.
Couple of questions though....
1. How long does replacing the bearings and seals take? Since the D is our only driver right now, is it something that I can do in an evening or wait until the weekend to do (ie, take more than a few hours)
2. Is it better / easier to work on the rear end with it still in the D, or would I be better off pulling it from the truck and working on it where I can get around on it?
3. The spec's for the pinion nut says I need to pre-load the crush cap to 210 ft/lbs of torque. The manual shows them using a beam type torque wrench for setting / measuring the pre-load. I also found a few video's on the 'tubes that show them using a beam type torque wrench. As my current "clicky" torque wrench only goes to 75lbs, I need a new one. However, the only beam styles I'm able to find (sears, snap-on, amazon, etc) only go up to 150 lbs. So the question is, where can I find a 250lb beam style torque wrench? Do I really need a beam style? What do you recommend (that's not going to cost me an arm and a leg)?
Old Jun 24, 2009 | 10:23 AM
datacop's Avatar
datacop
No one?
Old Jun 24, 2009 | 01:09 PM
Duranged408's Avatar
Duranged408
To my knowledge to replace the rear bearing you have to gut the rear axle, shim/dial's etc etc. Some people just remove the yolk and replace the seal without taking everything apart/add a new crush sleeve.. But since your leaking, have you checked your breather first before going on that mission?
Old Jun 26, 2009 | 02:44 PM
hydrashocker's Avatar
hydrashocker
Should be able to pull the yoke and replace the seal.
Old Jul 2, 2009 | 03:44 PM
datacop's Avatar
datacop
I'm going to pull the rear end this weekend and replace the bearings and seals...
I'll make sure and take pictures and document as well /nod
Hey Indy, wanna come over? Beer is cold
