2003 Durango SXT makes woo woo sound
Old Jun 22, 2009 | 10:46 PM
Yep Yep Yep's Avatar
Yep Yep Yep
Default 2003 Durango SXT makes woo woo sound
Bought my dodge a few years back and it has always made this woo woo sound when making a slow turn, like into a parking space, or going around in a slow circle the sound is comming from the rear end. No sound when going straight .
And no its not a train comming (lol)
Any one have this woo woo problem?
Old Jun 23, 2009 | 08:06 AM
Jmodix's Avatar
Jmodix
Short of you having Bubb Rubb in the back of your D, or a whistle tip.. (see below for both ) Odd that it only does it when turning. Are you sure it comes from the rear? maybe have someone drive around you slowing in circles while your out of the truck.. might help pinpoint the sound.
WOO WOO!!
http://www.youtube.com/watch?v=Nnzw_i4YmKk
Old Jun 23, 2009 | 10:28 AM
Duranged408's Avatar
Duranged408
Could be anything from tires/diff fluid - wrong fluid-no friction lube / wheel bearing. Its a toughy but make sure its coming from the rear first..
Old Jun 23, 2009 | 06:21 PM
hydrashocker's Avatar
hydrashocker
Possible no Limited Slip Friction Modifyer in the rear end?
Old Jun 23, 2009 | 07:56 PM
Yep Yep Yep
LOL, no thats not the woo woo I'm hearing LOL!
I sure its comming from the rear, I just replaced the speed/ABS sensor on the rear axel. the thing was completly destroyed, I must have pulled about 3ft of copper with a small magenet attached, some of the plastic housing fell into the case but figure the gears will chew that up in no time (I hope)!
Took it for a test drive and made a small circle and no
Woo Woo ?????
Thanks for the replys and 408 that's a great looking D...
Yep
Old Jun 23, 2009 | 08:48 PM
Duranged408
Thanks for the compliment
But back on topic... Was that sensor destroyed before removal, or during?
Im going to say your going to have to do some investigating and pop open the diff cover.........................................
Have a spare gasket/fluid first though
Better safe then sorry, axles are not cheap...
Old Jun 26, 2009 | 02:39 PM
hydrashocker
^ I totally agree ^
You need to get it out of there and it's not hard to pull the cover.
