engine overheats
Old Jul 7, 2009 | 09:26 AM
luckyone's Avatar
luckyone
Unhappy engine overheats
need help finding a hard plastic piece that fixs on the left side of the radiator @#$% mechanic tossed out found the one that goes next to a/c anyone know whats the part name per dealer they no longer make it
Old Jul 7, 2009 | 12:17 PM
IndyDurango's Avatar
IndyDurango
Not needed. Runs cooler without it.
IndyD
Old Jul 7, 2009 | 12:27 PM
Duranged408's Avatar
Duranged408
IndyD
X2
Wouldnt cause over heating.
What did the mechanic have to do that required the removal?
Maybe the coolant system was never burped?
Old Jul 7, 2009 | 04:34 PM
luckyone's Avatar
luckyone
Default engine overheats
well as luck would have it the engine siezed up so the mechanic was installing a rebuilt one - new engine seems to run hotter now then old did but when a/c is on the trans kicks out- any help i sure would appreciate it
Old Jul 7, 2009 | 05:56 PM
kev2's Avatar
kev2
when A/C on trans kicks out???
could you explain...
Old Jul 7, 2009 | 06:24 PM
hydrashocker's Avatar
hydrashocker
It's called the front clip splash guard.
Old Jul 7, 2009 | 07:00 PM
luckyone's Avatar
luckyone
yes the a/c is on when tranny kicks out. just replaced a/c condenser an still doing it. any advice?
Old Jul 7, 2009 | 07:14 PM
luckyone's Avatar
luckyone
it's not a splash guard it clips onto the radiator to help deflect air flow into the radiator
Old Jul 8, 2009 | 06:36 AM
kev2's Avatar
kev2
?? I cannot get a mental picture of your problem
give information ...
this is an automatic trans
driving along you turn on A/C ....
what happens- trans does??? explain...in detail...CEL comes on?, does DEFROSTsetting have same issue?
what have you done up till now?
and why?
Old Jul 8, 2009 | 07:18 PM
luckyone's Avatar
luckyone
Unhappy
heres the story easter weekend while driving on the highway my original engine with less then 85k blew. my mechanic found clogged with sludge so had a rebuilt engine from Jasper installed within week of getting it back it started overheating.
Now while driving in the city with a/c on the engine starts to heat up when it gets to about 235degrees the o/d light pops on and engine looses all get up an go and is sluggish. the clutch fan seems to work alot harder at that point.
so far we have replaced therostat, a/c condenser/ clutch fan, checked water pump (is ok), made sure sepentine belt is on correct, radiator not plugged or leaking, have checked various sensors , now checking intake manifold gasket if that is not it calling jasper engines for more advice.
i think my new engine bad but have to go thru motions to get new one installed. engine only has 1700 miles on it. if anyone has any ideas what is going on would appreciate it. we have not had any major issues until the engine locked up
