High idle
Old Jul 8, 2009 | 08:44 PM
BeachBoy's Avatar
BeachBoy
Default High idle
Any thoughts on what would cause a sudden, consistent idle of around 1200? By sudden, I mean the problem just showed up one day, and has been around since. No problem with cruise control surging.
Old Jul 9, 2009 | 12:41 AM
IndyDurango's Avatar
IndyDurango
Tps..
Old Jul 9, 2009 | 07:06 PM
hydrashocker's Avatar
hydrashocker
^TPS replacement^
Also while your there clean the IAC and Throttle Body.
Old Jul 9, 2009 | 08:25 PM
BeachBoy's Avatar
BeachBoy
10-4. Just checked the voltage on the TPS, and it is running high. Probably would read high no matter what was causing the idle to be high, but we'll give it a go. Thanks.
Old Jul 9, 2009 | 11:17 PM
hydrashocker
Here is how to properly set the TPS to .70 Volts:
TPS
Throttle Position Sensor Replacement for RPM surging and/or engine idle issues.
https://dodgeforum.com/m_53303/tm.htm
https://dodgeforum.com/m_1059612/...tm.htm#1059612
Throttle Position Sensor Modification for increased Performance. Scroll to TPS Modification:
http://bionicdodge.com/Download/Spee...d%20Tricks.pdf
