aftermarket cams
Old Jul 26, 2009 | 06:08 PM
mrwilliwizard's Avatar
mrwilliwizard
Default aftermarket cams
i have a question. for the 4.7l engine on the 2001 durango would h/o cams be better or the 206 cams? i heard that 206 cams could mess with your piston rings, caus eit will make higher compressions. what is your opinion on this? and where would the cheapest place be to buy such cams? thanks lots of places i look it says they are backordered. and for the 206 cams would it be simple enough to just swap stock for 206 cams? or do i need to replace other things like i heard some wher ei might need lash caps? what are those thanks.
Old Jul 26, 2009 | 10:51 PM
IndyDurango's Avatar
IndyDurango
What are you trying to achieve?
You can mod the hell out of your 4.7l and it will still be slower than a slightly modded 5.9L ya know. There is no substitute for cubic inches nor old school motors.
IndyDurango
Old Jul 26, 2009 | 11:53 PM
mrwilliwizard
i just want more power then a stock 4.7l durango. so i guess what im asking is which cams will give me the most power for my buck? also i cannot find any cams for the 4.7l that are in stock, so if you know of a place selling them please let me know
Old Jul 27, 2009 | 12:03 AM
IndyDurango
Get a tuner 1st.
Get a HO intake 2nd.
Get a Fastman TB 3rd.
Get 3.92 gears in rear end 4th.
Get Cams last.
Still be slower than a 5.9L
Old Jul 27, 2009 | 12:12 AM
Blown287's Avatar
Blown287
I'm running 206 Cams and you will need lash caps. If you buy 206 cams, make sure you buy a set with lash caps. If you go smaller grind i.e. 212 or smaller you will need a custom tune/flash, beehives valve springs and lash caps. Besides the blower, my 206 cams were one of my biggest power adders.
I will tell you this. I coudn't tell the difference between my HO cams and 206 until Hemifever wrote my cam tune. If you plan on 206s, I would look at a custom tune to bring them to life. Good luck.
Old Jul 27, 2009 | 01:13 AM
mrwilliwizard
onyl problem can't find any place that sells the cams for the 4.7l shows that they are all backordered on them
Old Jul 27, 2009 | 01:25 AM
Blown287's Avatar
Blown287
KRC still had 206s in stock but no HOs, have you tried them?
Old Jul 27, 2009 | 01:27 AM
mrwilliwizard
oh no i didnt look into krc but i will thank you!
Old Jul 27, 2009 | 01:28 AM
Blown287's Avatar
Blown287
You bet man. As of about two weeks ago they still had them.
Old Jul 27, 2009 | 01:38 AM
mrwilliwizard
doesnt matter if its for a dakota with a 4.7l right? same engine and everything just different body style? yea?
