MIL Light, need help
I have a dodge durango model SLT 2000, engine 4.7. Theres a light that popped up on the dashboard and it says MIL. I checked the durango handbook and it says its a 'ammission sensor'.
It has happened before so i changed the manuful gasket, and for a while it was fine. But it happened again and i have no clue of what it is. The car will start and drive fine for about 15 mins, but once the engine heats up it will stall. But once the engine cools down after about 10 mins i can drive it again. But then it will stall again.
I'm in Greece right now so i cant have the whole car checked via computer because they dont have that here.
I just want to know some of your oppinions of what it might be and what part i might need.
Thanks
Thanks
Pull the codes. Your rig has an on board computer dyno. (OBD-II)
Instructions on the top of the page: Engine Code Index (Check Engine Light?)
