codes! po715
my cel came on so I got a check done and it threw these codes:
po715 po731 732 734. It says its the speed sensor, but which one? I have the 4.7 engine. Should I change both or just the one thats throwing the code? Is my tranny shot? The other codes are gear ratio codes.
Symtoms: First gear seems fine, once shifts into second, will not down shift even when floored. Also on highway will not shift into od. No other lights are on.
