1999 Durango, ABS engaging at low speeds.
Old Aug 22, 2009 | 07:01 PM
jaymz56048's Avatar
jaymz56048
Default 1999 Durango, ABS engaging at low speeds.
Ok so my ABS light and brake light have been on for a few months. I came to this forum and figured out that it was the ABS sensor in the rear differential. Thank you everyone. Now after replacing the sensor, all the lights are off and it seemed everything was fine until i came to a stop. ABS pulsates below 20 mph. ( it never did this prior to the dash lights coming on a few months back ) Went out and did a few hard stops on the highway and the same thing, all fine until your about to stop and it pulsates close to 20mph-0mph. Got home and topped off the brake fluid, going to disconnect my battery maybe let the computer reset. Any other ideas???????????????????
Thanks, Jamie
Old Aug 22, 2009 | 08:28 PM
bigskiohio's Avatar
bigskiohio
send your abs unit in to rebuild on ebay.
Old Aug 22, 2009 | 08:31 PM
jaymz56048's Avatar
jaymz56048
Thanks, but if I can't do it myself, I"ll just pull the fuse.
Old Aug 22, 2009 | 10:21 PM
jaymz56048's Avatar
jaymz56048
I also just noticed the speedometer falls to zero while rolling about 10mph. will not kick back in until going over 10 mph. Could i have gotten a falty unit? i thought the speedometer ran off of the transmission?
Old Aug 23, 2009 | 12:33 AM
jaymz56048's Avatar
jaymz56048
All fixed, pulled the speed sensor back out, i assume it wasn't seated all the way.
Old Aug 23, 2009 | 10:58 PM
hydrashocker's Avatar
hydrashocker
^ You got it. ^
Thanks for the update!
