Front Shocks - ?
I was looking to try & replace the front shocks on my '03 by myself ($$ is kinda tight). The bottom looks pretty easy, just jack it up & undo the two bolts underneath the coil. But the top bolt is kind of hidden. Is there some trick to easily getting to it with a socket wrench?
Also, the shocks came with 2 overized washers & rubber bushings. Do both of these go on the bottom bolts?
I did the rears, & it was pretty straightforward. The fronts just seem a little harder for me.
Thanks for any help.
