Leaking Antifreeze
That's cheap. I'm running Magnecor's now. They are not so cheap. Since they are 3 years old, time for something new. I'm going LiveWires!
Looks great. IndyD
best I could find for ya
http://www.performancedistributors.com/livewire.htm
has number on page u may be able to call and get more specifics.
Im running .065" gap with no problems, the coil and wires do the trick...
Indy make sure you get larger wire holders if you do get the live wires, they wont fit any off the shelf product, i had to drill out plastic ones. They sell billet ones that do the trick.. Also if your getting the coil you'll need the adapter aswell..
Cant really get ya any good shots, im on 6 months 5 events mud dirt build up so the engine bay isnt the cleanest. (Remember im sportin no fenderwells so psssshhhttt on the dirty bay comments...) Ima try and get some time next week to run through and clean er up. I'd like to say im on 2+ years on these and still holding strong.. when i clean em up i'll show ya how purty they keep.
Freeze plugs, Okay, I haven't not thought of checking around that area or the lower area of the engine, but yeah, hopefully it is not. I only smell the antifreeze from outside the vehicle while engine is running. And I don't smell it all the time. Random times only. When I do smell it, it is feint, not a strong odor. But feint enough to cause me to look around. So far, everything on top of the motor to water pump is dry. Had a couple of shops did a visual inspection and did not find any either. I thought it may have been my heater core going out again but as the water is draining out of my drain tube from the evap core, I felt it and smelt it and no indication of antifreeze leak.
The last time I had leaks were coming from the t-stat housing and the return heater hose tube connected to waterpump. I have fixed both areas a long time ago and so far, they are still dry. If the leak is coming from t-stat housing, time for new intake manifold (edelbrock air gap!!) aluminum in that area is pitted up badly from previous leak. Also had the head gaskets replaced from dealer a while back before my factory warranty ran out.
But right now, I am monitoring my antifreeze fluid level. Been having to refill the reservoir every couple months. or every month if I drive it more often.
Replace the radiator cap with a 15psi. If you're smelling coolant it's probably letting pressure get by. I was having a problem with mine bubbling over into the overflow resevoir. I did a flush and fill and new cap. All OK now. Prestone sells a good kit. Quick & easy. Refill to at least a 50/50 mixture so that it tests out to 265 degrees before boil over.
Livewire = "A spiral wound core also offers extremely low resistance of 300 - 350 Ohms per foot for optimum spark travel."
MSD = "In a single 12 inch length of Super Conductor Wire there is only 40 - 50 ohms of resistance! That is the lowest resistance of any helically wound wire"
http://www.msdignition.com/product.aspx?id=6339
I wonder which one is better........... Not Livewire!
I run 0.42 gap on my MSD after indepth review into the hotter burning plug. I tried many different gaps and found this the best for me. No matter what you shouldn't need more than + .010 over OEM setting at .040 for the 5.9L and 5.2L respectfully. The output of the coil is 40,000 volts which the OEM is 36,000 volts. The MSD coil (8228) I run (which has a better name) runs the same 40,000 output and MSD stand by their products with the history as you can see. http://www.msdignition.com/product.aspx?id=5067
Here is the ignition I have with exception of the cap an rotor that I am doing a test with Echlin products. 50k + miles on these bad boys.
https://dodgeforum.com/forum/1st-gen...-ignition.html
My truck is leaking Antifreeze. Problem is, I cannot locate the leak. I am having to watch my reservior and have to refill it about every few months. It's a very slow leak. I took the truck to a couple places check for leaks and they cannot find it. Once in a while when the truck is idling, I can smell the antifreeze but still cannot find the leak. The leak must be small enough that it may hit the block and evaporate right away.
blown head gasket it will idle rough every six months to 8months to the point u have to replace the injector.
