2003 ABS Problem - need help
Old Sep 3, 2009 | 02:25 PM
swc103's Avatar
swc103
Default 2003 ABS Problem - need help
I have a 2003 Durango 4x4 with both the ABS and Brake light on and off. The alarm dings non stop everytime I speed up or slow down. I have checked the fluid and its fine. Unlike the other post, my speedo works fine.
Anyone know what I should check?
Thanks.
Old Sep 3, 2009 | 03:51 PM
kev2's Avatar
kev2
the key to this is knowing the ABS code....unfortunatly that requires a scanner capable of accessing ABS module...read big$$$$ tool.
without that you could check -
>.parking brake switch....set and release
>brake lights- all 3
>if you installed a trailer harness- dbl ck or unplug from vehicle T fitting.
>tires all 4 same size (if oem)
any changes made-work done reciently? changes in brake pedal feel?
Old Sep 5, 2009 | 11:35 PM
hydrashocker's Avatar
hydrashocker
Think the problem is the ABS module. You can pick em up on ebay.
