longevity of Durangos
Old Sep 20, 2009 | 02:56 PM
IndyDurango's Avatar
IndyDurango
LOL ROTFL!! I get it now. That one went right past me!! LOL LOL LOL!!!!
That would indeed be a great plus
IndyD
Old Sep 20, 2009 | 11:22 PM
hydrashocker's Avatar
hydrashocker
Ummmmm..........OK?
Old Sep 21, 2009 | 12:02 AM
buy american's Avatar
buy american
I have 100,000 more miles on my durango than that. 250,000 and runs strong. I keep up on maintenance oil changes, tranny fluid and filters, differentials, transfer case and greasings. I have had little problems. PCM box went, solenoid in the tranny, other than that normal wear items. The only thing I can recomend is check all your boot seals. Especially the one on the 4 wheel drive shaft. It is tucked in there pretty good on the transfer case end. You will know if it has been damaged for awhile when you put it in 4 wheel drive and you ripped out the splines on the shaft from all the rust.
Old Sep 21, 2009 | 12:04 AM
buy american
ok im an idiot just noticed it is 2 wheel drive. Well for those that have 4 wheel enjoy lol
Old Sep 21, 2009 | 12:56 PM
hydrashocker
^ lol ^
Old Sep 22, 2009 | 08:18 AM
MAGIC84's Avatar
MAGIC84
I am impressed with my D here are some major repair components and time/mileage for me.
purchased DEC06 62K
Tires Michelin X-rad X4 Jan 07 63.5K Alignment
Front/Rear pads/rotors MAR 07 64.5K
Blower Motor Resistor AUG07
Transmission JAN 08 76K NOTE TO SELF USE MOPAR SEALANT NOT GASKET
RH CV AXLE (DUST BOOT TORN) JUL08
4 Wheel Alignment AUG 08 (Western PA ROADS) BRAKE FLUID FLUSH/BLEED included in that project.
Blower Motor Resistor AND Wiring harness OCT 08
Rear Pinion Seal (Leak) JAN 09
WATER PUMP (FAIL) APR 09 103k Includes Thermostat/pump/both hoses and serpentine belt. I strongly recommend Goodyear Gatorback
SHOCKS X4 MAY 09 Bilstein HD
Rear Brake Pads JUL09 107K
Tire Rotation SEP09 108.5K Tread is still about 6/32 after almost three years and well over 40K miles. Tread depth was done by Costco but I watched them measure.
Front Brake pads/rotors SEP 09 109K Duralast C-max Ceramic
PAX Side HUB/Bearing assembly and CV AXLE (YES AGAIN, DUST BOOT TORN!) SEP09 109.5K
Exhaust, DYNOMAX, muffler back...Today wx permitting lets call it 110K
Transmission fluid filter later this week. I recommend a MAG-HYTEC pan, it is made for the 45RFE and 545RFE transmission and includes drain plug and cut out for temp sensor sending unit. $300 but will probably pay for itself after a couple of fluid/filter changes. Lowest price I found in the local area was about $150 and that is just fluid/pan/filter removal/replacement.
Alignment to follow soon after the transmission project.
Hope this helps.
Steve
Old Sep 22, 2009 | 12:45 PM
04vho's Avatar
04vho
Thanks for all of the comments and suggestions. I'm glad that there is a group like this that will help each other out, instead of one that will tell you all sorts of bs.
Old Sep 22, 2009 | 10:22 PM
hydrashocker
I like to type BS..........LOL
