gas tank,fuel pump,and regulator.
Old Sep 18, 2009 | 11:11 PM
iicon3's Avatar
iicon3
Default gas tank,fuel pump,and regulator.
hello everyone just a quicky. i'm sure some of you were aware that i had the fuel issues and bucking once in a while. and did what was recommended by the peeps from this thread.i cleaned out the fuel throddle body and cleaned the sensors.i right away saw a differance if the power but still have HORRIBLE gas milage.10 - 11 miles to the gallon.but the last time i put $20. bucks in i also threw in some gas treatment and some injector cleaner with the gas and i got aprox 13 miles to the gallon which is a litle better.no check engine light.last tune up was may (sparkplugs and wires) 2 months ago changed the oil,transmission filter and fluid.also re torqued those 2 bolts that was recomended in the manuel.changed the valve gasket seals.and replaced the air filter.
i was told to do a fuel pressure check but just havent gotten to it yet but will in a day or two. any other possiblities why the d is sucking the gas down like beer on a hot summer day??
as for my second question i came across a guy the is selling parts off his d.soo off course i jumped on the tires,rims,hitch,and some other odds and ends that i know will come in handy in the future.i also told him that i might want his gas tank just because im also having an issue with either the fuel pump or the fuel regulator. ok now heres the question i have a 5.2 and his is a 5.9.are they the same??
Old Sep 19, 2009 | 02:19 PM
hydrashocker's Avatar
hydrashocker
It's the same pump.
Have you tried to modify your TPS or have you replaced the IAC or MAP sensors?
Also, you need to do a full reset of the PCM any time you mess with sensors. Look at the front of this thread: Engine Code Index (Check Engine Light?)
Old Sep 19, 2009 | 11:20 PM
iicon3's Avatar
iicon3
Originally Posted by hydrashocker
It's the same pump.
WOW I LOVE YOU GUYS!!
the only thing that i did was clean the tps and blew off the iac sensors. how do i modify them?and how do i know when they need replacement.
Old Sep 20, 2009 | 11:18 PM
hydrashocker
This information is located in the same thread: Do It Yourself (top questions and answers) FAQ's
The information is located within the thread I posted.
Here is a direct link and download of the pdf.
Throttle Position Sensor Modification for increased Performance. Scroll to TPS Modification:
http://bionicdodge.com/Download/Spee...d%20Tricks.pdf
Surging up and down while at freeway speeds or really noticed when the cruse control is on as well as bucking has been noticed. Also stumbling from a stop.
