Odd door buzzer and lights not working issue
Old Sep 19, 2009 | 05:26 PM
03rtdurango's Avatar
03rtdurango
Default Odd door buzzer and lights not working issue
I have a 2003 Dodge Durango R/T and at speeds of 50 mph or more the door ajar buzzer dings constantly. Anyone have this issue or know how to remove the buzzer? Also, from time to time the headlights stop working and if you disconnect the battery and reconnect, they work fine....
Thank you!
Old Sep 19, 2009 | 06:08 PM
schusterjo's Avatar
schusterjo
door buzzer one i would check the door adjar switch in the door jam (open the door and look where the door hinge is, you will see a button there.)
The headlight one i have heard of before but do not remember the fix, will let Indy take a shot at that one or perhaps Hydra has heard of it.
Welcome to the forum by the way.
Old Sep 19, 2009 | 06:17 PM
03rtdurango
Thanks!
I checked the buzzer and everything appears normal. Just odd that it does it at a certain speed.
Old Sep 19, 2009 | 06:30 PM
schusterjo's Avatar
schusterjo
Originally Posted by 03rtdurango
Thanks!
Just hold tight and a few will come threw here and may have ur answer. may take a day or two but they will be threw here.
Old Sep 19, 2009 | 06:35 PM
03rtdurango
After some more searching on here, it seems like it may be a problem with the CTM. I'm open to any suggestions though.
Thanks again
Old Sep 19, 2009 | 10:05 PM
IndyDurango's Avatar
IndyDurango
Beat me to it. Yep. Your CTM is intermittent. $450 dealer only repair. Take both key fobs with you to the swap for reprogramming.
Once your dash lights start going on and off, your hedlights stop working completely, the door chime at all speeds now and then and the horn starts honking on it's own... the CTM is shot then and you will have to take it in.
Sorry. Good luck.
IndyD
Old Sep 20, 2009 | 11:06 PM
hydrashocker's Avatar
hydrashocker
CTM sounds right.
