Clattering on cold starts
Old Sep 20, 2009 | 03:26 AM
Durango03's Avatar
Durango03
Default Clattering on cold starts
Not sure if its always done it and I never noticed it, or it just started. But when I cold start my "D", It sounds like theres not enough oil and the engine is knocking for like 2-3 seconds then sounds fine. Anyone have any ideas? I use Full Synthetic oil BTW.
Old Sep 20, 2009 | 12:34 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
if you have the 4.7 anytime it sits for a long period of time (6-8 hours +) there will be a lifter tick, its normal, mine has done it since my parents bought it new
as long as it goes away with in a fe second (the longest i think mine lasts is maybe 30 sec after starting) then i wouldnt worry about it
Old Sep 20, 2009 | 02:59 PM
IndyDurango's Avatar
IndyDurango
+1. 4.7s tend to 'slap' at start up. Keep the oil changed regularly to make sure that isn't adding to the issue which could cause damage afterwards.
IndyD
Old Sep 20, 2009 | 06:59 PM
Durango03's Avatar
Durango03
Thanks guys! Strange I never noticed it before.
Old Sep 20, 2009 | 11:30 PM
hydrashocker's Avatar
hydrashocker
Could also be a bad anti-drain back valve in the oil filter so you can change the filter but it is normal to hear that on the 4.7L.
