Water pump replacement stubborn fan clutch nut
Old Sep 29, 2009 | 03:11 PM
leonardo's Avatar
leonardo
Default Water pump replacement stubborn fan clutch nut
My water pump recently went out on my 98 5.2L Durango. Lucky me it has the pressed on pulley. I tried to remove it with the belt on a hammer. No luck. I removed the belt, and managed to put a u-bolt through one of the holes. Wedged a long screwdriver in there and pounded on it. The thing is not moving. Am I missing something? I have the "righty-tighty, lefty-loosey" thing down. Not sure what to do and don't want to pay someone $600 to replace the pump.
Thanks
Old Sep 29, 2009 | 04:38 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
get a BFH (big f*cking hammer) and a BFW(same thing just a wrench ) and bang on it until the nut loosens up, soaking it w/ nut buster (pb blaster, wd40 ect) should help to loosen up the nut and banging on it after putting the oil on the nut is supposed to help it work into the threads (as per the directions on the can of it that i have in the garage at home )
Old Sep 29, 2009 | 05:04 PM
SumAmerican's Avatar
SumAmerican
Default get a new wrench
you see the wholes in the pulley?? you need to head out to the store and pick up a spanner wrench. a spanner wrench will have two studs that fit into the wholes on the pulley and will keep it from moving.. pulling the clutch nut will still be a handfull.. get a buddy to help
Old Sep 30, 2009 | 12:18 AM
hydrashocker's Avatar
hydrashocker
Get a big hammer and a lot of beer. If the fan don't come off at least you can catch a drunk!
When I did it I took a pipe wrench (large) left the fan belt on and smacked it with a 4 lbs sledge. Also had a screw driver in the hole as well and everything locked down tight when I smacked it. The other thing you could do is get the right tool......LOL
You are correct. Lefty loosey on that. Turn the nut counter-clock wise.
Old Sep 30, 2009 | 07:47 PM
kid289's Avatar
kid289
i did mine same as shocker. pipe wrench. it works, just be in inventive
Old Sep 30, 2009 | 08:45 PM
schusterjo's Avatar
schusterjo
This will help you
https://dodgeforum.com/forum/1794061-post38.html
Old Sep 30, 2009 | 10:53 PM
hydrashocker
That write up is going to be everywhere ya know schusterjo!
Kid<------Did ya catch the drunk I was talkin about!.......
Old Oct 1, 2009 | 12:53 AM
IndyDurango's Avatar
IndyDurango
How much could a new pulley cost? Can't you change the pump and the put a new pulley on there at the same time. Wouldn't that be easiest for maybe $20?
IndyD
Old Oct 3, 2009 | 01:01 PM
leonardo's Avatar
leonardo
thanks everyone, I am working on it again this weekend. I soaked it with pb blaster and now I will make that tool. I looked around for a spanner but I would have to order one.
Is there enough clearance to remove the water pump with fan attached?
I will let you know how it goes.
Old Oct 3, 2009 | 10:45 PM
hydrashocker
I think so but it will make it harder in the long run.
