heater core removal
My heater core has sprang a leak (fluid out evap drain)and I have started to to take it apart to replace it My question is do i have to remove everything to the windsheild? Also how can disable the air bags?
The dash needs to come out and then the heater box. Disconnect the battery to disable the air bags. You don't need to remove the radio, but you will need to remove the steering colum.
