Fitzall 220 AMP Alternator Install?
Old Oct 6, 2009 | 08:44 PM
HiJackZX1's Avatar
HiJackZX1
Question Fitzall 220 AMP Alternator Install?
I'm sorry for resurrecting an old thread, but I am wondering how do you install a universal alternator. I recently bought a Powerbastards.com Fitzall 220 AMP alternator. It has its own built in regulator, so how do I connect this to the car? Will the PCM throw out error codes when it is no longer connected to alternator?
The three connections that the new alternator has is a light wire (I guess to make the warning light come on), a ignition wire, and a sensing wire that connects to constant 12V+. Maybe I do not need any of them?
Old Oct 7, 2009 | 01:10 AM
hydrashocker's Avatar
hydrashocker
Please give us the year, motor, ect. and electrical schematics of your replacement.
Old Jan 24, 2010 | 03:27 AM
HiJackZX1's Avatar
HiJackZX1
Oh wow, forgot all about this thread. i drive a 2003 Dodge Durango SLT. Has the 4.7L Magnum v8. After researching, i found out that it was to much hassle to try to replace the alternator. Instead what I am doing is adding the alternator as a second one and running a dedicated line from the second alternator to the audio and pc equipment. It will save alot of headaches running them seperate.
Old Jan 24, 2010 | 10:35 AM
Dman98's Avatar
Dman98
Got my 200 amp from here; http://www.motorcityreman.com/ works perfectly. Very good company, I also have one for the car and it comes with a lifetime warranty.
Old Jan 24, 2010 | 11:11 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would expect that running a second alternator would be harder than replacing yours as you need custom mounts and a new belt and new belt routing and a whole extra set of wires, and probably another battery so that the alternator is never running without some load on the system
Old Jan 24, 2010 | 06:53 PM
hydrashocker
+1 Sharps!
You will need to install a second battery and run the system off of that as well with the mountings and load on the engine. To ensure draw form the battery on the secondary system I would install a diode between the two batteries and hook them up together.
