Engine Light On
P0442 Evap Leak Monitor Medium Leak Detected
its an evap leak, check that the gas cap is on tight, if it is might be time to replace it
if that doesnt fix the problem (it comes back after you reset the light) start checking for broken/cracked/damaged vacume hoses
idk why but i get a series of evap leak codes every fall but they go away once the cold temperatures stabilize (btw i have the same 4.7l engine)
Yeah, what sharp said, check your vacuum lines. Might be helpful to check the hoses coming from the gas fill neck to the tank and also the vacuum canister located near the front of the gas tank bolted to the frame rail. All those hoses need to be replaced if cracked. JHMO. HTH.
