Durango Delima
Old Oct 18, 2009 | 01:57 PM
hydrashocker's Avatar
hydrashocker
I thinks it's the Camshaft Position Sensor.
Could also be the crankshaft sensor but first try ^ one.
Old Oct 18, 2009 | 02:28 PM
pappa golf's Avatar
pappa golf
Cool
The crank and cam sensors control spark not injector pulse, right ? Besides my scanner shows that the two sensors are in sync.
Old Oct 19, 2009 | 11:52 PM
SumAmerican's Avatar
SumAmerican
any charging issues?? when the alternator failed in my 5.2 it was hell trying to track down.. kinda doubt its the alt but try getting it started while hooked up to a running truck..
Old Oct 20, 2009 | 10:12 PM
hydrashocker
Then I would go to PCM other than checking the battery/alt like ^ Sum ^ is saying.
Old Oct 21, 2009 | 12:04 PM
pappa golf's Avatar
pappa golf
thanks for all your help, when i get it figured out i'll let you know what it was.
Old Oct 21, 2009 | 02:25 PM
hydrashocker
Check all fuses including the PDC fuses under the hood. Clean the harnesses.
Camshaft sensors also control pulse.
