Durango Delima
Old Oct 16, 2009 | 01:02 PM
pappa golf's Avatar
pappa golf
Cool Durango Delima
I have a 2000 Durango I'm working on that won't start. Cranks fine, has 48 Psi. fuel pressure while spinning, good spark, and compression. No injector pulse. No codes stored in engine or body. not sure if this vehicle has a pats system or a vats system or neither. any help would be greatly appreciated. thanks
Pappa Golf
Old Oct 16, 2009 | 06:35 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
which engine do you have in the truck, the 5.9 or the 4.7? this will make a difference in what we suggest for you
Old Oct 16, 2009 | 07:55 PM
pappa golf's Avatar
pappa golf
Cool
sorry for not including that information before. i have the 5.9
Old Oct 16, 2009 | 08:03 PM
pappa golf's Avatar
pappa golf
Cool
vin code is a z
Old Oct 16, 2009 | 08:51 PM
hydrashocker's Avatar
hydrashocker
Do you have an aftermarket alarm system?
Old Oct 17, 2009 | 12:25 AM
master tech's Avatar
master tech
Site Moderator & Tech
Try spray starting fluid down the throttle and start. If it starts, you may have a bad fuel pump. You may have good pump pressure, but do you have volume.
Old Oct 17, 2009 | 11:01 AM
pappa golf's Avatar
pappa golf
no after market alarm. havent starting fluid yet but like i said earler i have no injector pulse. fuel volume would not affect injector pulse, would it ?
Old Oct 17, 2009 | 11:28 AM
hydrashocker
I don't think so! Are you getting spark at TDC?
Could be also the PCM.
Old Oct 17, 2009 | 01:07 PM
pappa golf's Avatar
pappa golf
yes only thing i dont have is injector pulse
Old Oct 17, 2009 | 01:09 PM
pappa golf's Avatar
pappa golf
already swapped pcm from another durango i had, same year and engine. diddent make a difference.
