our 2001 Durango has started squeaking as the suspensions moves while driving. 121,000 miles. Is this shocks? struts? springs? all? can't isolate squeaks but seems to be front end. MOVED QUESTION TO SUBGROUP PER ADVICE FROM FORUM MODERATORS. THX.
Reason: moved to subgroup
99.99% that it is the swaybar bushings. Using silicone spray is very short term and I did that for a while but after a couple more years, the bushings pretty much dry rotted and nothing you put in there can stop the squeaking. Just replace the bushings and you are good to go.
