'01 V8 overheated today...
Old Nov 9, 2009 | 03:59 PM
alth3655's Avatar
alth3655
Default '01 V8 overheated today...
Sorry, should have put 5.9 in the heading, Newbie, help me out... I have a 2001 Dodge Durango 4 wheel drive, 5.9 V8. Yesterday, I smelled just a hint of coolant as I put the heat on, but saw no smoke and the temp was running normal. I drove probably 40 miles yesterday total, in several spots, including city and highway miles. Today, I get in the car and go to work. A 6 min drive, about 4 miles highway, and the other 2 city. When I pulled into work, smoke was coming from the hood, and the temp gauge said I was running hot. I popped the hood and the smoke was coming from the radiator and just a small amount of leakage. Could this just be a pinhole in the hoses? The therm could be bad? Are these coolant systems hard to flush? 140k miles
Old Nov 9, 2009 | 10:24 PM
brad8266's Avatar
brad8266
You saw leakage and smelled coolant, find the leak and correct it.
Old Nov 9, 2009 | 10:48 PM
IndyDurango's Avatar
IndyDurango
Most common failure is the entire upper hose contraption. $45 dealer only item. Swap it out. Also, look down at the stat, any leaking around the neck is an indicator the stat & gasket need swapped too.
Here is my upper hose story: (Mis)adventures of a blown hose
IndyDurango
