Brake & ABS Lt. on above 35mph + C.C. out
Old Nov 11, 2009 | 07:13 PM
TWray's Avatar
TWray
Default Brake & ABS Lt. on above 35mph + C.C. out
I'm happy to return to this super forum for Mopars. Its been a while since I have visited because of net & Comp issues. But let me thank all those that have provided a good source of info and entertainment. My Dodge is shaping up cause of it.
I have an 01 Durango and the ABS + Brake lt has been coming on and the cruise control has stopped working + the speedo IS working fine...This only happens after I bring the vehicle above 35 mph. The light does not come on til then. But it consistantly comes on above 35 and then stays on until I shut the vehicle back down. Any ideas?
Old Nov 12, 2009 | 12:03 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you could try changing the transmission speed sensor (its on the output shaft of the transmission) but that usually causes shift problems too but its only a $35 so it cant hurt to try, it fixed my old truck
Old Nov 12, 2009 | 10:11 AM
hydrashocker's Avatar
hydrashocker
Also couldn't hurt to change the speed sensor as well. This is the number 1 issue for cruise and ABS issues. Besides they usually go out about the same time and they work together anyway. Rear Axel Speed Sensor / Rear ABS Sensor DIY
Old Nov 15, 2009 | 12:08 AM
TWray's Avatar
TWray
Thanks for the info folks. Thought that may be the case from past posts...Just wanted some more reassurance for what MAY be the culprit.
