4.7 engine interchange
Old Nov 15, 2009 | 09:43 PM
bcv021's Avatar
bcv021
Default 4.7 engine interchange
2000 d 4.7L motor is knocking on the right top. What other year/vehicle will work?
Old Nov 15, 2009 | 09:49 PM
IndyDurango's Avatar
IndyDurango
2000-2003 4.7s for the least amount of crossover issue. Basically plug and play on those.
IndyDurango
Old Nov 16, 2009 | 01:08 AM
hydrashocker's Avatar
hydrashocker
IndyDurango
Accept the 16 pin and 32 pin connection. Other than that, the motors are the same.
Old Nov 17, 2009 | 07:12 PM
bcv021's Avatar
bcv021
What do you mean 16/32 pin connector/
Old Nov 17, 2009 | 07:55 PM
dbilik's Avatar
dbilik
They mean you are running what is reffered to as a JTEC computer in those years. The only real difference between any 4.7 is the tone wheels. And I won't agree with you being able to take an '03 Durango motor and plug and play into a '00. '03 was the year of the change to the NGC computer, which utilizes a 32 tooth tone ring. You, on the other hand, are using a 16 tooth tone ring. Easiest way to tell if you are JTEC or NGC is to look at the computer, if it has 3 plugs on it you are JTEC, if it has 4 you are NGC.
HOWEVER, you can swap tone rings. It is a little bit of a PITA but it is possible. I am taking an '03 Durango motor and putting it into my '01 Dakota Quad Cab right now.
Old Nov 17, 2009 | 08:02 PM
dbilik's Avatar
dbilik
https://dodgeforum.com/forum/2nd-gen...2001-qc-2.html
Here is a link to the thread that I posted about some of my work, and there is a link there to my flickr albums showing the two engines.
If you can find it, a 4.7 from some early Jeeps are HO (High Output) and JTEC controlled, it would not only swap in without switching rings, but it would also be HO.
Old Nov 18, 2009 | 12:16 AM
hydrashocker
Do you know which Jeeps years and type?
Old Nov 18, 2009 | 08:04 AM
bcv021's Avatar
bcv021
Ok now I no! Let us all know about the Jeep years! Thanks
Old Nov 18, 2009 | 10:01 AM
dbilik's Avatar
dbilik
I cannot vouge for its accuracy, but it looks to be a good resource.
http://www.wjjeeps.com/ho_engine.htm
Double check the computer though when you see one.
Old Nov 18, 2009 | 10:04 AM
dbilik's Avatar
dbilik
http://en.wikipedia.org/wiki/Chrysle....7_HO.2FMagnum
http://www.allpar.com/mopar/47.html
