Bad Alternator?
Old Feb 16, 2010 | 11:56 PM
  #21
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Originally Posted by hydrashocker
Remove the alarm.
i agree pull it out and consider reinstalling it later if you really want it
Old Feb 22, 2010 | 10:49 AM
  #22
kazeej's Avatar
kazeej
The alarm is no longer in the truck. Where else should I look?
Old Feb 22, 2010 | 02:31 PM
  #23
hydrashocker's Avatar
hydrashocker
Did you check and clean the grounds on the battery cables both sides?
Old Feb 23, 2010 | 09:35 AM
  #24
Dans01Durango's Avatar
Dans01Durango
So your D won't start even with the alarm out. Could be the neutral saftey switch. After you drive around for a while, getting the engine hot, can you restart it after a half hour or hour later? Mine was like that and the experts here and on another board have narrowed it down to the neutral safety switch. That may be your problem. I think your nss is located on your tranny. I may be wrong so let's hear from the experts!
Old Feb 23, 2010 | 10:33 AM
  #25
shrpshtr325
THE ULTI-MOD
i agree with dan, nss is a real possibility, but until we know which engine trans combo we cant point you to it(i may have missed it, if i did im sorry)
Old Feb 23, 2010 | 10:54 AM
  #26
hydrashocker
Swap out the starter relay with one of a same number in the under the hood PDC.
Hard starting and stumbling with excessive fuel to start could be a Camshaft Sensor. First thing first, check the ground to chassis connections and clean the connections and re-bolt. Clean the Throttle Body and IAC.
When’s the last time you did a tune up?
And finally, what motor/trans combo are we working on???????
Old Feb 24, 2010 | 09:17 AM
  #27
kazeej's Avatar
kazeej
Here's a review of what we're dealing with here, so we can get back on track.
2000 Durango Sport 5.2l 5 speed automatic, a/c, tow package, 100k miles.
Truck will crank, but will not fire.
Alarm was suspected, but is no longer in the truck.
All battery connections are clean, new battery, new alternator.
Pulled a spark plug to check for spark, plug was wet with fuel - no spark.
Old Feb 24, 2010 | 02:11 PM
  #28
hydrashocker
Check the coil.
Old Feb 24, 2010 | 02:46 PM
  #29
shrpshtr325
THE ULTI-MOD
not a 5 spd i garantee it , 5 speed was not available till 03 model year (officially, my 02 was a floor model for a now 03 color and got the 5 spd) and was only available with the 4.7l engine everything else got 4 spds
Old Mar 5, 2010 | 08:25 AM
  #30
kazeej's Avatar
kazeej
Check the coil.
Thanks, Hydra. I finally have a day to work on this again. I'll start there.
Jack
