stock suspension,rims, and tires
Old Dec 8, 2009 | 11:30 PM
mrwilliwizard's Avatar
mrwilliwizard
Default stock suspension,rims, and tires
on the 4x4 durango with the stock 16 inch rims. what is the widest tire i can get? because if i increase the height it might rub and throw off my speedometer so i was wondering in width how fat i can get those suckers. it's almost time to replace my good year forteras for some all- terrains.
thanks
Old Dec 9, 2009 | 01:48 AM
Digitoxin's Avatar
Digitoxin
I cant tell you what the largest tire size is that will fit off hand, but I increased the tire size on mine to 265/75/16 's.
Old Dec 9, 2009 | 02:46 AM
mrwilliwizard
thanks. do the rims you have on in the pic have the same specs as the oem rims?
Old Dec 9, 2009 | 11:42 PM
hydrashocker's Avatar
hydrashocker
Whats up Digitoxin? Long time!
Old Dec 12, 2009 | 08:01 PM
mrwilliwizard
do you guys know the specs of the stock rims on the 2001 durango? are they 16 " in diameter and 10.5 " wide?
Old Dec 12, 2009 | 09:46 PM
IndyDurango's Avatar
IndyDurango
Digi, great hood BTW.
Nice!
IndyDurango
Old Dec 13, 2009 | 10:58 PM
hydrashocker
16X8 on that.
Old Dec 18, 2009 | 03:26 PM
mrwilliwizard
i just looked at the sticker thats on the inside of the door. and it says the rims are 15X7 ??? also shows p235/75/15 and something saying 15xl. but the tires i currently have on are (p265/70/16) whats up with that? im confused lol.
Old Dec 18, 2009 | 03:40 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
that means your truck came from the factory with 15x8 (i think) rims and 235/75/15 tires, the differnt tire size means that someone changed the tires and put the wrong (bigger, not always a bady thing) size tire on it, your speedometer is probably off at this poinunless the P/O had it calibrated to the new tire size
Old Dec 18, 2009 | 05:01 PM
mrwilliwizard
ive had the durango from the start all the way back to 2001 brand new 17 miles off the line. no one changed the rims. but the tires fit perfectly fine on the rims . the tires say dont mount on anything but 16 inch rims since thats what it was made for. idk lol. on tire rack if you look for o.em wheels they have a 265/70/16 option. so im guessing thats a wheel option my parents got when they first bought the car.
last thing what are you guys pumping your tires to? what psi? on the door it says front cold 35 psi and rear 41 psi. is this correct? my tires max psi is 44.
