2000 durango crankshaft pos sensor problem
Old Dec 11, 2009 | 04:26 PM
mrmadhat's Avatar
mrmadhat
Default 2000 durango crankshaft pos sensor problem
ok here is my problem.about 2 weeks ago my durango wouldnt start. p340 error code.I replaced the crankshaft position sensor,it solved my problems for about a week.I parked my vehicle went into a store and it wouldnt start when I came back,same error code.replaced the part again thinking it was a shabby sensor.now I have the same error code again and the durango starts sometimes..it wont start,go back a couple of hours later and it fires up on the first crank,error code will still show after clearing the codes and 5 min of driving. can anyone give me an idea of what else to look for?
Old Dec 13, 2009 | 10:25 PM
hydrashocker's Avatar
hydrashocker
Look at the harness and any other connections regarding it's operation.
Old Nov 8, 2010 | 03:08 PM
srevilla's Avatar
srevilla
Default I'm Having the same problem!
Hello, i´m having the same problem with my Durango 2000 5,9, it wont start and i get the same error code p 340, did you solve the issue? if so, would you help me? Thanks
