big UHOH
I recently replaced my tie rods,upper and lower ball joints, and shocks.making VERY SURE that I set the tie rod length exactly the same as the old ones, but now my tires are not aligned at all.what have I done!?!?
I'm sure the play in the tie rod ends, and ball joints screwed up the aglinment. You can't replace parts in the front end without doing a 4 wheel aglinment. THis is why the lifetime aglintment over at Firestone for like $150 is a Great deal! You can have it done anytime you want for free! The shocks didn't do anything.
Go get it done...
Any replaced tie rods,upper and lower ball joints setup should ALWAYS be followed up with an alignment. Until so, you are not done and risk damage to the $800 new parts and labor you just installed.
IndyDurango
IndyDurango
Sorry about the doublepost, I couldn't find my post, so thought somethin had happened to it, idk. Anyway, I'm afraid to drive it to the alignment shop, its THAT off,
Trending Topics
I messed adjusted the tie rods and then got it to the shop, and then they told me that they can't do the alignment until I replaced the passenger side hub bearing, so got the timken bearing from autozone and installed it, gona drive it back up to the shop tomorrow to get the align done
