Orginal Battery in a 2002 is this possible?
Yes, sir! Plug ins for these cold winter nights. Gonna use the included o-ring terminal with fast disconnect and an extension to the charging pack in the garage. Wifey took over the garage, now it's a storage room.
Gonna run the wire under the garage door under the hood of the D.
iv never found i needed a battery tender, and YES i park outside it cranks a little slower int he cold, but as long as i let the pump prime before turning it over in the morning its fired up pretty damn good IMO
I wish I can say that. There seems to be a slow drain somewhere and I haven't nailed it down. But if I don't drive the D for a few days, the batery dies. I know, I'll have to nail that drain down soon. The tender is a bandaid.
well the indicator is probably LED so it wont draw down much, i used to leave my phone charge plugged into the always on socket in the center console and that thing would sit for weeks and still start you might have a short somewhere, start pulling non essential fuses from the fuse box one at a time until you it stops draining, than something powered by that fuse is the problem
Remove a fuse at a time and stick an ammeter in place of the fuse, if you get sockets with current flowing through them you need to see why there is current flowing through it when the car is off. Any normally off circuits shouldnt have current flowing. If all checks good the battery itself is probably defective.
